Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
Mar 26, 2019Guru - Experienced User
Maroman
Mar 27, 2019Guide
I didn’t realize there was a new firmware available. I just updated yesterday so I’ll try it out and see if the issue is resolved.
Thanks.
Thanks.
- FURRYe38Mar 27, 2019Guru - Experienced User
Ok keep us posted. If the new FW doesn't resolve, lets contact NG support about it.
Thanks.- MaromanMar 27, 2019GuideYeah sounds good. I’m also reading that after the firmware update I should probably do a factory reset in both router and sat.
I’ll do that just to be sure.- FURRYe38Mar 27, 2019Guru - Experienced User
Please, this will help ensure the FW got steated well and gets a good clean setup from scratch.
:smileywink:
