Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
Maroman
Mar 27, 2019Guide
Yeah sounds good. I’m also reading that after the firmware update I should probably do a factory reset in both router and sat.
I’ll do that just to be sure.
Mar 27, 2019Guru - Experienced User
Please, this will help ensure the FW got steated well and gets a good clean setup from scratch.
:smileywink:
