Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
Sam540
Mar 27, 2019Aspirant
Any word on this, the lack of the traffic meter working is very concerning.
Maroman
Mar 28, 2019Guide
Just tested with latest firmware (V2.3.1.44) on both my router and satellite. Reset both to factory settings and the same behavior that I had on the older firmware is still happening on the latest update. If I disable DST the traffic meter works for a little but eventually the NTP page sets the time to DST automatically which therefore breaks the traffic meter.
