ronealwa
Mar 11, 2020Star
Orbi Traffic Meter stopped working
In the last several days the Traffic Meter on my Netgear Orbi system mysteriously stopped working. All entries reverted to zero even though I have traffic flowing every day. I googled the issue a...
- Mar 14, 2020
Maybe I'm missing something but there seems to be a simple work-around for this.
Turn off DST and then select a time zone that gives you the correct time. That will provide traffic and the correct time. Come November when the time changes back, you can just adjust your time zone back to the correct zone for your location.
Retired_Member
Mar 11, 2020
ronealwa wrote:In the last several days the Traffic Meter on my Netgear Orbi system mysteriously stopped working. All entries reverted to zero even though I have traffic flowing every day.
I googled the issue and found a solution about turning of the "adjust for daylight savings time" option under the NTP Settings under the Advanced>Administration>NTP Settings.
When I turned this off and saved, magically the Traffic Meter readings came back and everything seems to be working fine now except that my "Orbi clock" is now off by 1 hour because the Adjust for DST option has been turned off.
Is this a known bug and is Netgear actively working to fix it?
Thanks.
so this has been an issue for 2 years and there is still no fix?
https://community.netgear.com/t5/Orbi/Orbi-Traffic-Meter-Issue/m-p/1499209
