rv13
Apr 25, 2019Follower
Orbi Tri-Band Cable Modem Router (CBR40) & Orbi WiFi System (RBK50) AC3000
I am looking to purchase a new mesh system for my home. Currently I am in a home that runs DSL and was going to purchase the Orbi WiFi System (RBK50) AC3000. My plan is to move into a home in the n...
michaelkenward
Apr 26, 2019Guru - Experienced User
rv13 wrote:
so was I thinking of purchasing Orbi Tri-Band Cable Modem Router (CBR40) .
If you want to use an Orbi router you would do better to buy a "modem only" cable modem.
Not only will this save you money, it will give you an easier network to manage.
Check the "CM" models here:
Fastest Cable Modems | Cable Modem Routers | NETGEAR
When it comes to using the Orbi stuff in your new home, reset it all back to factory settings so that it forgets any configuration picked up when you get it working in your current location.
