Grandmstrbud
Apr 26, 2020Aspirant
Orbi Tri Band on wired backhaul
I'm looking at giving this setup a try again. I am wanting to get the tri band 2 pack where I will connect the devices with wired backhawul. I realize the 2nd 5.0Ghz radio is reserved for wireless ba...
- Apr 26, 2020
When the router and satellite are connected with ethernet cable, that 5G WiFi "backhaul" radio remains active and reserved for backhaul. Cannot be used for user devices. Sorry.
CrimpOn
Apr 26, 2020Guru - Experienced User
- GrandmstrbudApr 26, 2020Aspirant
Thanks for the quick reply this helps.
