RhondaK9
Feb 27, 2022Aspirant
Orbi TriBand Whole Home Mesh WiFi System (RBK23) - Can I temporarily disable the non-2.4 ghz network
Orbi TriBand Whole Home Mesh WiFi System (RBK23) - Orbi AC2200 - Does anyone know, is it possible to temporarily disable the 5 ghz networks on this router? I love the router, and how it works, but...
- Feb 28, 2022
RhondaK9 wrote:
But, the plug will only allow set up on a 2.4 ghz negwofk, so the set up fails.
This is because the plug is made by people who do not know what they are doing. I have installed IoT things that use 2.4 GHz and can happily set them up with a phone on 5 GHz. It is the same network after all.
If you can find the name of the plugs, then it may be possible to run a search here and to see if someone has worked out how to get it to cooperate.
The "move away to lose the 5GHz" trick seems to work for some people. You can leave the plugs connected to the electric, but move the phone down the road until 5 GHz fails. After all, 2.4 Ghz has better range at slower speeds.
It is a pity that all phone makers don't allow users to pick their bands.
Other users dig out an old wifi repeater, or something else that they can force on to 2.4 GHz, and then to set up using that. Once set up, these things tends to stick.
Agree, that the manufacturer should develop devices and apps that allow for both networks, and there are more expensive devices that works with both, but I usually buy the less expensive "four for the price of one" smart devices, and I have always been able to set them up, until recently. I don't know why it is a problem now, but this is definitely a common complaint, according to my research online.It is probably the growth of Mesh system. Netgear is not alone in hitting this brick wall.
Feb 27, 2022Guru - Experienced User
Its not an option. You can't disable the 5ghz.
You can reduce the 5ghz signal and disable the "broadcast ssid signal". The 5ghz still broadcasts but it doesn't show as an ssid. then when you disconnect, reconnect your phone, theres a better chance it connects to 2.4ghz.
Another option i used to use was use a phone as a hotspot and name it the same ssid/password as my router. I'd disable my router and turn the hotspot on. then I'd setup my devices. Once setup, you could turn off the hotspot and turn the router back on.
