RhondaK9
Feb 28, 2022Aspirant
Orbi TriBand Whole Home Mesh WiFi System (RBK23) - Orbi AC2200
Does anyone know, is it possible to temporarily disable the 5 ghz networks on this router? I love the router, and how it works, but I am running into trouble trying to set up some of my smart devi...
RhondaK9
Thank you for taking the time to help me.
Sorry to sound uninformed, but how do I find "web administration". Does that require that I connect direct to the router through its IP address?
CrimpOn
Feb 28, 2022Guru - Experienced User
This is exactly correct. The User Manual explains the process several times (at the beginning of many different topics). See, for example, pages 22, 25, 57....
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
The typical method is to connect to the Orbi network (wired or WiFi), open a web browser and enter http://orbilogin.net. If this does not work, use the IP address of the Orbi router, which is often 192.168.1.1.
