gandres2
Dec 17, 2017Follower
Orbi Troubleshoot
The past several months I have noticed my internet connection has been on/off. I thought it was my internet provider but they said they checked my signal and it is fine. They said it might be the r...
DarrenM
Dec 19, 2017Sr. NETGEAR Moderator
Are you on the latest firmware? Have you tried to adjust the wireless channels on your wireless networks? In the advanced wireless settings have you tried to enable beamforming and MUMIMO?
DarrenM
- ncharityDec 20, 2017Aspirant
I am having the same disconnect problems with my mobile phone (Samsung S6). The disconnects occur both when I move around the house, but also when the phone is not being moved. I have already done the following:
Firmware updated to the latest version: V2.1.1.16
Turned off Daisy-Chain Topology
Turned on BEAMFORMING, MU-MIMO, Fast Roaming
The device is being used in bridge mode, but the problem is NOT to do with my Modem/Router. I have checked any DCHP / IP clashes, and the disconnects don't happen with this first Modem/Router (when I turn it's wifi on).
My house is modern and has thick walls/ceilings that make wifi difficult. We have had difficulties filling the space with wifi from "cheaper" routers, so I decided to invest - for me - really serious money at three times the cost of any router I have ever bought to finally solve the problem. I am bitterly disappointed with Netgear that buying this state-of-art, "best on market" device is resulting in connection problems. If these cannot be cleared up I will be returning the router in the next few months. When the connection is present however, the quality is really good and solves my problem. I would therefore beg Netgear support to provide me with a solution.
- ncharityDec 21, 2017Aspirant
More feedback:
When I turned on Fast Roaming I believe the problems became worse. Connection was lost within a couple of minutes. I have now turned it off and, even though the disconnects are still occuring, they are less frequent. Hope to get some feedback on this issue from Netgear before teh Christmas break.
- Madrigal4747Dec 22, 2017AspirantI gave up on Orbi. I went through all trouble shooting online and when I went to call for support, I was told that I was outside of the 90 days free support window and I would have to pay for premium support. I feel that I should not have to pay for support on a product that I paid so much money for. I'll never purchase any other Netgear product again.
