slums
Dec 18, 2016Aspirant
Orbi turns Magenta after some days working OK
My orbi router occassionally (but every day) has the ring turn magenta and internet connection is lost. It will stay solid magenta for about 30 seconds or so and then turns off as internet connectio...
DarrenM
Dec 19, 2016Sr. NETGEAR Moderator
Hello Slums
You may just want to move the satellite a little closer to where the main Orbi is just could be losing signal at certain times from something interfering. Also make sure you are using the latest firmware.
DarrenM
slums
Dec 23, 2016Aspirant
Thx. I've done those and it still happens. The satellite ring does not change color when the router turns solid magenta.
