FJB6439AspirantMay 09, 2019Orbi Ultra Perf Thinking of getting the Orbi Ultra Perf router and 2 satelites. Am I able to connect 1 of those satelites to the router via ethernet cable? Need to run cable in pipe under road to my shed. Show More
FURRYe38Guru - Experienced UserMay 09, 2019Yes: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
FJB6439Aspirant to FURRYe38May 09, 2019Just to be sure (no IT guy here) One sattelite can be wired and the other wireless? Thank you
FURRYe38Guru - Experienced User to FJB6439May 09, 2019Yes. Daisy Chain feature may need to be disabled if connected via ethernet.
