Jongemini75017's avatar
Nov 11, 2019
Orbi Ultra WiFi mesh extender doesn’t do it for me
Bought the NETGEAR Orbi Tri-band Whole Home Mesh Wi-Fi System. I set it up as directed. Although the satellite was located in the bedroom above the router, the Wifi was still poor. Overall it was no b...
  • Retired_Member's avatar
    Retired_Member
    Nov 15, 2019
    A couple of items to consider:
    2.5.0.38 has known issues.  You may want to see if you can roll your firmware back.
    Looks like the ZYXEL VMG8924-B10A is a dual router/modem.  If this is true, it requires special config to make it work with the Orbi.  You really don't need or want 2 routers in your network.
