Jongemini75017
Nov 11, 2019Aspirant
Orbi Ultra WiFi mesh extender doesn’t do it for me
Bought the NETGEAR Orbi Tri-band Whole Home Mesh Wi-Fi System. I set it up as directed. Although the satellite was located in the bedroom above the router, the Wifi was still poor. Overall it was no b...
- Retired_MemberNov 15, 2019
A couple of items to consider:
2.5.0.38 has known issues. You may want to see if you can roll your firmware back.
Looks like the ZYXEL VMG8924-B10A is a dual router/modem. If this is true, it requires special config to make it work with the Orbi. You really don't need or want 2 routers in your network.
Retired_Member
Nov 15, 2019A couple of items to consider:
Jongemini75017
Nov 15, 2019Aspirant
Thanks for taking the time to help. It looks like I'm not going to be successful with this unless I buy a new modem-only rather than my existing modem-router. I did some research on the Orbi but there was no mention of not working correctly with dual modem routers which are the norm in the UK. I have already spent a lot of money on the Orbi kit (router plus 2 extenders) so my best bet would appear to be to return this product to the reseller and to revert to my DEVOLO mesh extenders instead - which gave me better coverage.
Thank you.
Jongemini75017 wrote:Thanks for taking the time to help. It looks like I'm not going to be successful with this unless I buy a new modem-only rather than my existing modem-router.
Please keep in mind, many folks here have been successful in running the Orbi with a dual modem/router. It just takes a few extra steps.
- FURRYe38Nov 15, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Jongemini75017 wrote:Thanks for taking the time to help. It looks like I'm not going to be successful with this unless I buy a new modem-only rather than my existing modem-router. I did some research on the Orbi but there was no mention of not working correctly with dual modem routers which are the norm in the UK. I have already spent a lot of money on the Orbi kit (router plus 2 extenders) so my best bet would appear to be to return this product to the reseller and to revert to my DEVOLO mesh extenders instead - which gave me better coverage.
Thank you.
