CaptStevo
Mar 17, 2017Star
Orbi unable to update time v1.8.0.6
Hello all, After updating to v1.8.0.6 my orbi has been unable to update its system time. I have tried via Advanced->Security->Schedule to change timezones, check and in check adjusting for DST, wit...
CaptStevo
Mar 26, 2017Star
Thanks for your reply.
My Orbi does not update after reboot (or ever) - anyone know of the best way to get debug information to Netgear engineering?
So far I have only been able to update my Orbi's time via telnet ntpclient command manually.
st_shaw
Mar 26, 2017Master
CaptStevo wrote:Thanks for your reply.
I noticed mine was set on the wrong time zone and wasn't tracking DST. When I applied those settings it synch'd via NTP immediately.
Stupid questions, but:
Are you certain the router is set to log NTP synchs (this can be unchecked)?
Could something on the network (firewall, your ISP, etc) be blocking NTP to or from the Orbi router? I know you said you set it manually, but did you synch to the same server Orbi uses by default?
