CaptStevo
Mar 17, 2017Star
Orbi unable to update time v1.8.0.6
Hello all, After updating to v1.8.0.6 my orbi has been unable to update its system time. I have tried via Advanced->Security->Schedule to change timezones, check and in check adjusting for DST, wit...
st_shaw
Mar 26, 2017Master
CaptStevo wrote:Thanks for your reply.
My Orbi does not update after reboot (or ever) - anyone know of the best way to get debug information to Netgear engineering?
So far I have only been able to update my Orbi's time via telnet ntpclient command manually.
I noticed mine was set on the wrong time zone and wasn't tracking DST. When I applied those settings it synch'd via NTP immediately.
Stupid questions, but:
Are you certain the router is set to log NTP synchs (this can be unchecked)?
Could something on the network (firewall, your ISP, etc) be blocking NTP to or from the Orbi router? I know you said you set it manually, but did you synch to the same server Orbi uses by default?
CaptStevo
Mar 27, 2017Star
Well, you were right. It took a bit to nail the cause down, but AT&T blocks outbound UDP connections on port 123. This is apparently to cut down on DDoS attacks - but it renders the Orbi unable to update its time.
I have seen other posts in the Netgear forums that indicate that Netgear engineers were able to create firmware versions that could update timestamps without depending on port 123. If Netgear sees this, I'd be willing to help solve the issue! I may have to return my Orbi if I can't use it with AT&T.
I was able to confirm that using a non-standard NTP port updates the Orbi's time flawlessly. Logging in via telnet and executing:
ntpclient -h "time-g.netgear.com" -b "time-h.netgear.com" -i 15 -m 60 -p 123 -s
...fails (using port 123).
When I tried the same command, with a non-standard NTP port:
ntpclient -h "time-g.netgear.com" -b "time-h.netgear.com" -i 15 -m 60 -p 1238 -s
...it worked flawlessly.
I've been attempting to find a workaround for two days now. Perhaps I can execute a cronjob to update the time correctly, but I don't believe it will survive a reboot.
- st_shawMar 27, 2017Master
I'm glad my comments helped you determine the cause of the problem.
If you cannot change the command Orbi uses to synch, one thing you might be able to do is setup your own ntp server on your LAN, using a Windows box, a Linux machine, Raspberry Pi, etc. Then direct the Orbi to that server on the LAN. You could potentially do that by adding a fixed-IP entry for the LAN ntp server in Orbi with the host name time-g.netgear.com.
As long as Orbi would resolve time-g.netgear.com to the LAN IP it should work. I'm not sure whether Orbi's internal name resolution would pick it up properly though.
I believe Windows can serve as an NTP server natively.
- CaptStevoMar 27, 2017Star
"You could potentially do that by adding a fixed-IP entry for the LAN ntp server in Orbi with the host name time-g.netgear.com."
Do you know of a solution to do this? I didn't see a /etc/hosts file on the Orbi, and looking at the static routes page didn't offer an obvious solution.
DHCP address reservation via the GUI. See page 64 of the user manual. (http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf)
Reserving an IP address should setup Orbi's DNS to resolve the entered host name to the LAN IP address.
I know this would work on other routers, but I'm running my Orbi in AP mode, so I cannot test it.
Until Netgear adds an option to use an alternative port to sync with NTP servers, this problem will persist. My research indicates that UDP NTP traffic is now blocked by several ISPs, so this problem will continue to pop up until Netgear addresses this issue.
My only potential solution would be to have a machine act as a DNS server as well as an NTP server - quite the workaround that most users will not be able to do.
Thanks for all the help so far. I'll update if Netgear contacts me.
