Biigdaddio
Nov 02, 2019Aspirant
Orbi under the sofa!
Sadly in my old home with lathe and plaster and thick timber, the best place to put my base unit is under the sofa. I gave it a try and it seemed to work fine without getting too hot, but I'm a littl...
CrimpOn
Nov 02, 2019Guru - Experienced User
Under a sofa is a "new one" for me. Some small things to consider:
- Orbi is definitely designed to stand vertically. The circuit board is oriented so that cool air will enter at the bottom and hot air will exit at the top. https://community.netgear.com/t5/Orbi/Understanding-Orbi-Radio-Fronthaul-Backhaul/m-p/1671092
- The omni-directional antennas create a horizontal circle (actually a torus - torroid?) so a good portion of the signal is radiating in directions that are not particularly useful.
- It's a bit difficult to see the "ring light" if the unit is under furniture.
However, as long as you get the service you want, I'd say, "go for it."
