PeterSchneider
Apr 28, 2021Star
Orbi Upgrade from RBR50 to RBR850 or RBR750
A post to comment, and perhaps generate conversation, on Netgear's lack of technology exchange to upgrade path. An example that I have is the Orbi RBK530 and that I would consider moving up to the R...
PeterSchneider
Apr 28, 2021Star
CrimpOn, Will let you know how my research goes, if I remember to post back here. The habit is that once someone decides to leave they don't generally look back.
As for the automobile dealer, might have more to do with the ones I deal with, but the point is that automotive companies appear to think more about customer retention than Netgear does.
Apr 28, 2021Guru - Experienced User
Be sure to visit the Orbi AX forum for additional information and support.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
