wifiblues
Jun 30, 2020Luminary
Orbi upgrade
hi -
i currently am using the RBR20 router and supplement with 3 Orbi Satellites.
if i upgrade to RBR43, can i use the same three Satellites?
thanks,
Wifiblues
- wifibluesLuminary
Thanks CrimpOn!
1 more question.
the RBR43 is packaged with 2 satellites already. Are they the same satellites as the plug in kind?
thanks,
Wifiblues
The RBK43 package includes one RBR40 router and two RBS20 satellites. They are not the "plug in" RBW30 model.
Here's the product data sheet:
https://www.netgear.com/images/datasheet/orbi/RBK43.pdf
I believe "plug in" refers to the RBW30:
https://www.netgear.com/images/datasheet/orbi/RBW30.pdf Some people find them convenient. My personal opinion is not as positive because (a) I am not positive that they allow the bottom electrical outlet to be used, (b) they provide no ethernet ports of any kind, and (c) the design practically shouts out, "put me down by the floor, where I radio signal will be blocked by appliances, furniture, cabinets, and I will be strangled by dust bunnies."
