gorstj
Apr 04, 2018Initiate
ORBI UPNP not working when device connected to satellite
Using latest firmware 2.1.3.4. RBR50 is in Access Point mode wired to my ADSL router (Fritzbox 7390) Anything attached to my RBR50 (main) either wired or wireless is able to use UPNP port mappin...
- Apr 04, 2018
Always good to sort out your own problem - hope it ssaves someone elses time!
I have disabled 'enable daisy chain topology' in my Orbi router advanced wireless settings. UPNP now works perfectly
I presume this is a bug?
Apr 04, 2018Guru - Experienced User
Have you tried wired back haul?
After updating FW, did you factory reset both router and Satellite then set up from scratch?
Wonder if you changed to router mode on the Orbi router and set up this way if anything changes. Only seems like Satellite is having the problem. Was the FW updated on the Satellite as well?
What devices do you have connected to the satellite?
