beastlove
Nov 19, 2018Aspirant
Orbi UPNP Portmap Table Blank
Hi
I am having some trouble with my sons PS4 and NAT. It comes up with a message that voice chat will not work due to his NAT settings and I think it might be something to do with UPNP
I'...
beastlove
Nov 21, 2018Aspirant
Thanks FURRYe38 . Voice chat is working now but the UPNP table is still blank. Doesn't really much difference but still odd none the less. I am guessing this must be a firmware bug or something. Thanks to all for the help and advice.
Nov 21, 2018Guru - Experienced User
Possible issue in FW. You should make contact with NG support about this. Hopefully some engineering review will be done.
