Yamster2016
Nov 09, 2017Aspirant
ORBI UPnP Xbox One Issues
Hi Guys, I have having lag issues and I think it's due to ports not being opened correctly. When I check the router i can see the following port is being used 3074 but what i dont understand is n...
DarrenM
Nov 13, 2017Sr. NETGEAR Moderator
Have you done all the port forwarding for xbox or try putting the xbox in the DMZ?
DarrenM
