slygato's avatar
slygato
Orbi USB 2.0 port
The whole sales spew for Orbi is about throughput, throughput & even more throughput.  Then they put a single USB 2.0 port on the thing?  Here's some perspective:  http://bestwirelessroutersnow.com/why-get-a-wireless-router-with-usb-3-0/  I put in my pre-order for the Orbi on August 22nd but I'm thinking of backing out and waiting on USB 3.0 so that I can put a big honking media drive on it and get some decent throughput out of it.
  • slygato's avatar
    slygato
    Aug 26, 2016
    I hadn't considered that.  It crossed my mind that it would be cool if I could use one of the 1gb Ethernet ports for a storage connection, but I haven't spent any time at all looking into this (obviously.)  I'll look into what's available and put a temporary moratorium on my carping about the USB 2.0.
    My other concern was regarding the RF radiation from these puppies and from what I've been able to determine, these things will be putting out about 36dbm (about 1 1/2 Watts) and that a person five feet from the the unit will be irradiated with a -30dbm signal, which is 60dbm down. I'm not an engineer but -60dbm is a million times less (at least it is on the farm where I was raised.)  From the experts at Drudgereport.com and other authorities, 5Ghz is non-ionizing radiation which is far safer than ionizing radiation.  The point being, maybe I'll put aside my concerns about USB 2.0 and RF radiation and not cancel the order.  At least these are things to think about during the next two weeks.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The key feature of Orbi is the whole home Wi-Fi and that's what our focus has been on.
    USB3 is great, but working with a USB disk does use up resources that the router could use for something else.
    If you want to use USB3 you could connect a Nighthawk via Ethernet to the Orbi router and connect the USB disk to that. One of the two routers should be in Access Point (AP) mode to avoid double NAT.
    Or better yet you could connect a NAS such as our ReadyNAS via Ethernet. The NAS has a number of backup options and with multiple disk bays a redundant RAID level could be used to provide some protection against a disk failure.
    • slygato's avatar
      slygato
    • Vinchenzo's avatar
      Vinchenzo
      So you want me to buy a whole new router that has USB 3.0? That doesn't seem to be cost effective for the end user, does it? By the way, you did not mention what resources would be used up and why that is a negative impact on the Orbi.
      • slygato's avatar
        slygato
        Valid points.  I have a R7000 Nighthawk and I believe it has a USB 3.0 connector but if there is a single Ethernet connection between the Nighthawk and the Orbi, I would probably do better with a NAS with an Ethernet connection.  How about a 10gb Ethernet port on the Orbi or a USB 3.1?  More is better.  I imagine these will be available at some point.
  • Bottom line, can the USB 2.0 port on the Orbi be used to connect an external hard drive? I have very basic network storage needs so it not being a USB 3.0 port would not be a deal breaker for me.. None of the other new mesh networks have USB ports which can be used for network storage AFAIK.
      mdgm-ntgr
      No
      • loomis1975's avatar
        loomis1975
        Luminary
        What is the functionality and purpose of the usb 2.0 ports on the router and the satellites?  If I cannot put a external storage device on it for backup, is it only for connecting printers?  Or what else?
