avatar123
Jan 05, 2017Tutor
Orbi USB NAS support
1. When is Netgear planning to release the firmware update what would enable the provided USB port functional? I don't understand what's taking them so much time to release the firmware update. 2. W...
Nsiddons
Jun 13, 2017Apprentice
I agree 100% about the app. I looked at a clients eero and they have such a comprehensive app with data speeds and more
Bing-Stroller
Jun 13, 2017Luminary
On the 11 Jun 17 peteytesting wrote
well it seems one of the requests has been activated with the usb 2 ports now working for both printer and usb dongle and hdd for sharing
and went on to clarify
yes seems to in the beat release that been passed out , no detail yet on config or anything else
It looks as though although in the beta release it is not in the publicily available firmware. Fingers crossed things go well and it makes it to general release.
- peteytestingJun 13, 2017Hero
yes a beta release that has been handed out to some public users and was reported by one of those users as working
- NsiddonsJun 13, 2017Apprentice
I would be interested in joining the beta program. I wonder if the final release of the update will support Apple time machine, I'm guessing it would be great either way.
- BigLouJul 23, 2017Aspirant
I'm in the same boat, I guess I should have researched this more before buying. I just purchased the RBK50 today and expected to be able to connect my external HDD for Time Machine backups. All I get when trying to connect is "There are no shares availaboe or you are not allowed to access them on the server." The "orbilogin.com" configuration doesn't have a page to setup a HDD, it currently only has a page for ReadySHARE Printer.
If there is a beta program or a firmware upgrade (since the last reply in June), I am interested in joinging as well.
- peteytestingJul 23, 2017Hero
might have been a good idea
if the ip address is the default on type \\192.68.1.1 into windows file explorer
the beta testing is full and you may have to wait for further fw updates , btw what fw are you on as you may need to manually update to the latest
depending on your model goto
https://www.netgear.com/support/product/orbi.aspx
download the right fw and manually install
never said it would support apple TC , just that its usb dongle and hdd connectivity will actually work
