none5x
Apr 21, 2017Tutor
Orbi USB port
I purchased an Oribi around Christmas time from Costco. When the networked USB hard drive that I plugged into the unit did not work, I called into Orbi tech support and was told that the Orbi's USB ...
- Apr 22, 2017
there is a simple answer and thats to put that hard drive in a real nas unit with ethernet as its connection method and this way you will get fast speeds from your hard drive as even if the usb does get activated ( which i doubt ) it would only be usb 2 and quite slow with hdd and the like
i see the new rbk40 and 30 dont even have usb at all , so i would suggest its not ever going to be a usable feature on the rbk50 ether
none5x
May 24, 2017Tutor
Darren,
Thank you. Do you have an ETA when I will be able to hook up an external hard drive for network back up purposes? I'm feeling like this has been outstanding for a long while and am thinking about returning my unit to Costco to buy a different device.
