seamonkeas
Jan 30, 2019Aspirant
ORBI used as Gateway Slower than 1GB Connection
Hello,
I'm having trouble getting the RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z, I have no issues. Wh...
seamonkeas
Jan 31, 2019Aspirant
- I've never used QOS and already factory reset it (again)
- Yes, I'm using ethernet to the PC
It is a night and day difference if I use the Century Link Modem on it's own.
"ISP modem as your router and then use the Orbi in AP mode."
I'm currently doing this, but it seems to block my web services on the ISP modem. They work fine on the orbi by itself.
Feb 01, 2019Guru - Experienced User
If the Orbi is in AP mode, then it's only working as a pass thru for traffic. There is no routing.
For any PF configurations, you'll need to look into the ISP Modem/router to ensure it's correctly working well.
Are you testing the speedtest app with in the Orbi UI or using a Wired PC connected to the Orbi and using speedtest.net windows or mac app?
