seamonkeas
Jan 30, 2019Aspirant
ORBI used as Gateway Slower than 1GB Connection
Hello,
I'm having trouble getting the RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z, I have no issues. Wh...
Theskyfell
Mar 06, 2019Initiate
I was wondering if there was ever any resolution to this? I am having the same issue but a little more extreme. I just got CL Gb fiber and can only get 470 mb down and 170 mb up. What’s worse is I am lucky to get even half of that over WiFi.
I have the C3000Z in transparent bridge mode and the Orbi is connected via a 5e cable. I am at my wits end on how to improve this. Currently my connection is worse now on the DL side then it was with Comcast but I have faster service.
It is PPPoE. Any ideas would be greatly appreciated.
Mar 07, 2019Guru - Experienced User
Seen others with same issue with PPPoE. Something you'll need to contact NG support about. https://www.netgear.com/mynetgear/registration/login.aspx
What happens if you change the modem back to router mode and configure the Orbi for AP mode?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Ensure your speed testing with a wired PC.
