madmaxx_71
Dec 14, 2016Star
Orbi useless for IPTV (no multicast/IGMPV3)???
Hi everyone, I just installed my new Orbi System (also ran the firmware update, currently 1.4.0.18) with 1 satellite and everything seemed to run pretty smoothly. That was until I switched on my ...
- Feb 23, 2017
The new FW Version 1.5.0.12 should support IGMP Proxy!
http://kb.netgear.com/000037330/RBR50-RBS50-Firmware-Version-1-5-0-12
TheEther
Dec 14, 2016Guru
The only setting to try is to enable IGMP Proxy in WAN Setup.
madmaxx_71
Dec 14, 2016Star
Hi Ether, thanks for trying to help, but I can´t find anything of relevance under WAN Setup...
These are my options in WAN Setup:
| Disable Port Scan and DoS Protection | |
| Default DMZ Server | . . . |
| Respond to Ping on Internet Port | |
| MTU Size(in bytes) | |
| NAT Filtering | Secured Open |
| Disable SIP ALG |
Do you have any other ideas? Thank you.
Cheers, Alex
- TheEtherDec 14, 2016Guru
Strange that it's not there. Try performing a reset to factory settings. If the setting is still missing, then you may have to resort to using the Orbi as an AP instead of a router.
- madmaxx_71Dec 14, 2016Star
hi Ether,
thanks for your effort, but both solutions didn´t work out...
Cheers, Alex
