madmaxx_71
Dec 14, 2016Star
Orbi useless for IPTV (no multicast/IGMPV3)???
Hi everyone, I just installed my new Orbi System (also ran the firmware update, currently 1.4.0.18) with 1 satellite and everything seemed to run pretty smoothly. That was until I switched on my ...
- Feb 23, 2017
The new FW Version 1.5.0.12 should support IGMP Proxy!
http://kb.netgear.com/000037330/RBR50-RBS50-Firmware-Version-1-5-0-12
Ganter
Dec 15, 2016Aspirant
Hi
Did you use German IPTV ?
madmaxx_71
Dec 15, 2016Star
Hi Ganter,
yes, T-Home Entertain to be precise. And my ISP ist Deutsche Telekom as well...
Cheers,
Alex
- GanterDec 15, 2016Aspirant
Ok, that´s makes me more relaxed. Could you please tell me something about the Setup you made?
I assume you use orbi as Acces Point ?
And you are using the MR400/MR200 as Receiver?
Did you made any special Set up or just plug &play?
Thanks
- madmaxx_71Dec 15, 2016Star
This is the setup I tried but which failed (screen freeze):
Modem/Router: FritzBox 4790
Orbi Router, setup as Access Point, plugged into FritzBox
Telekom Media Receiver 303A+ plugged into Orbi Satellite.
Orbi Wifi workes like a charm otherwise.
I tried all sorts of tweaks in the FritzBox and Orbi setups, nothing worked.
I keep getting hints that I should use a switch which has IGMP snooping, but given the above setup, where should I put it? It just seems that the Orbi system is not able to handle multicast...
Hope this helps
Alex
rookie8155 could you please tell us which entertain Receiver you are using how is your setup; Just PLug&play or any special setup?
Thanks
