madmaxx_71
Dec 14, 2016Star
Orbi useless for IPTV (no multicast/IGMPV3)???
Hi everyone, I just installed my new Orbi System (also ran the firmware update, currently 1.4.0.18) with 1 satellite and everything seemed to run pretty smoothly. That was until I switched on my ...
- Feb 23, 2017
The new FW Version 1.5.0.12 should support IGMP Proxy!
http://kb.netgear.com/000037330/RBR50-RBS50-Firmware-Version-1-5-0-12
Ganter
Dec 15, 2016Aspirant
Hi rookie8155
Thanks for your reply. That means Netgear Orbi does not work for German IP Televison as it cannot handel Multic Cast Datas IGMPv3 as it used from german Telekom fro their IPTV.
I will use than instead Devolo Gigagate to get the IPTV Receiver connected .
Thanks
Ganter
Dec 16, 2016Aspirant
- chrzaFeb 23, 2017Guide
- madmaxx_71Feb 23, 2017Star
It works!!! Thanks Netgear, now I am a happy customer;)
