jeraboom
Oct 13, 2017Star
Orbi V2.0.0.74 - iPhones constantly losing Internet connectivity (but not WiFi connectivity)
I think I've been more than patient with my 6-month-old Orbi System, but this is getting ridiculous. Since "upgrading" to V2.0.0.74, our iPhones are constantly losing their Internet connectivity. The...
Spaceman29
Oct 18, 2017Guide
Same issue here.After the 2.0 firmware update i find this issue more frequent.
Iphones keep logging off or webpages slow down.
My hue lights dont connect or respond to echo and the problem is frequent downtime of internet.
I have tried to disable the daisy chain option, reduce the transmit power of 2.4ghz,
repositioned the satellite adn router for minimum interference as well.
It works as a trial and error basis without any permanent solution.
Hope the orbi team recommends some fix for steady connection inspite of losing speeds.
Waiting for some kind of help that worked for somebody to try cos i am stuck with the expensive mesh system and cannot do much now.
