jeraboom
Oct 13, 2017Star
Orbi V2.0.0.74 - iPhones constantly losing Internet connectivity (but not WiFi connectivity)
I think I've been more than patient with my 6-month-old Orbi System, but this is getting ridiculous. Since "upgrading" to V2.0.0.74, our iPhones are constantly losing their Internet connectivity. The...
AlexH2018
Jun 07, 2018Aspirant
Firmware 2.1.4.10 here and my iphone X drops the wifi connection very frequently...
Jun 07, 2018Guru - Experienced User
What iOS version is on the iPhone?
Is the iPhone connecting to the router or satellite?
What channels are you using?
What Mfr and model# ISP modem is the Orbi connected too?
Disable MIMO, Daisy Chain and Fast Roaming.
Try the newer FW verson v16:
Try a full factory reset on both Router and Satellite then set up from scratch. This needs to be done coming from older FW versions..
