jeraboom
Oct 13, 2017Star
Orbi V2.0.0.74 - iPhones constantly losing Internet connectivity (but not WiFi connectivity)
I think I've been more than patient with my 6-month-old Orbi System, but this is getting ridiculous. Since "upgrading" to V2.0.0.74, our iPhones are constantly losing their Internet connectivity. The...
Jun 07, 2018Guru - Experienced User
What iOS version is on the iPhone?
Is the iPhone connecting to the router or satellite?
What channels are you using?
What Mfr and model# ISP modem is the Orbi connected too?
Disable MIMO, Daisy Chain and Fast Roaming.
Try the newer FW verson v16:
Try a full factory reset on both Router and Satellite then set up from scratch. This needs to be done coming from older FW versions..
AlexH2018 wrote:
Firmware 2.1.4.10 here and my iphone X drops the wifi connection very frequently...
