RussFogg
Mar 05, 2020Tutor
Orbi V2.5.1.8 issue
Hi, 2 days did a auto FW update from the app which prompted me - it was V2.5.1.8 Since then the RBR50 reboots itself every 20min I have done the following in the order I have listed... ...
theoak
Mar 05, 2020Luminary
I acutally just down graded from 2.5.1.8 to 2.3.5.30. I could not get the online GUI or the iOS app to report reliably for me on 2.5.1.8. Actually it did start with flaky wifi so I reset the devices. Stabilty seemed to be restored after the reset, but then the connected devices went south on me regardless of the GUI. The online GUI also reported my Satellites as not connected.
The online GUI seems to want to auto-upgrade me when I go to the Firmware menu, but if I click on another menu item, it never really starts. The iOS app has this Update button, but it is not automatic. With a little luck I don't tap it :) If I go to the satellites individually they show up as 2.3.5.30.
Once I down graded either GUI seems to be accurate as to my environment. People seem to either hate or love 2.5.1.8. Good luck.
CrimpOn
Mar 05, 2020Guru - Experienced User
If you mark the post "Solved", then readers will know that no more effort is required.
Sorry you had to go through this.
