alkdlk
Dec 20, 2020Follower
Orbi, Verizon Fios, and Lutron Smart Bridge
Equipment Orbi RB854K (1 Router and 3 Satellites) Verizon Fios Quantum Gateway Router Modem Lutron Casetta Smart Bridge (L-BDG2-WH) and some Lutron Cassetta switches I have been successfully u...
Dec 20, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you.
