Danteorbi
Aug 30, 2019Aspirant
Orbi verliert Verbindung zu LG TV über Ethernet
Hallo und schon einmal vielen Dank für die Antworten. Ich habe ein sehr skurriles Problem - vermute ich. Ich habe ein Orib Mesh System mit einem zentralen RBR50 und zwei RBS50 Satelliten. Die Ver...
Danteorbi
Sorry ... I wasn't aware, that this is an english forum.
Translated Text:
Hello and thank you very much for the answers. I have a very bizarre problem - I guess.
I have an Orib Mesh system with a central RBR50 and two RBS50 satellites. The connections seem to be stable and are also displayed "green" in the app. The DNS assignment is done by a Fritzbox 6490 which is connected to Unitymedia.
The latest firmware is installed and the WiFi works very well.
Now to my problem: I connected my LG TV via Ethernet directly to one of the satellites via cable. The connection works. Everything is fine. But quite often it happens that the TV loses the connection. It then shows this and has to reconnect. The phenomenon has never happened to me before with a cable connection. I also changed the port in the Orbi satellite. Unfortunately no result.
Would any of you have any idea why that is and what I could do?
Oh yes, it's not the TV. That worked before with a Devolo DLan completely unproblematically.
Many thanks and many greetings
Translated with www.DeepL.com/Translator
- FURRYe38Aug 30, 2019Guru - Experienced User
What mode is your modem working on? Router or modem only?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Thank you for kindly translating. :smileywink:
