Ryganley
Mar 27, 2020Follower
Orbi very slow or unreliable
I have since transferred my house and a external building (20 feet away) to the orbi Tri band system with the hub on the main floor (same as the old router) one satellite in the upstairs bedroom and ...
Mar 27, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.
You may need the 50 series Orbi, as it seems to have more power and range over the 20 series.
- Retired_MemberMar 27, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).You may need the 50 series Orbi, as it seems to have more power and range over the 20 series.
too many questions.....:smileysad:
