Ryganley
Mar 27, 2020Follower
Orbi very slow or unreliable
I have since transferred my house and a external building (20 feet away) to the orbi Tri band system with the hub on the main floor (same as the old router) one satellite in the upstairs bedroom and ...
Mar 27, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.
You may need the 50 series Orbi, as it seems to have more power and range over the 20 series.
Retired_Member
Mar 27, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? The DIR-868L is not a modem. Good router though.What is the size of your home? Sq Ft?
too many questions.....:smileysad:
