sdevine88
Jun 12, 2021Follower
Orbi Voice Connecting
Thinking about changing to Nighthawk but needed to know if Orbi voice connect to Nighthawk AX1800 WiFi 6.
sdevine88 wrote:
....connect to Nighthawk AX1800 WiFi 6.
What's that?
AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Try the section given over to that device:
Orbi Voice - WiFi Meets HiFI - NETGEAR Communities
the orbi voice has both an Orbi mode and an Extender mode.
So you should be able to put it in extender mode and connect to most routers.
How do I setup my Orbi Voice RBS40V in Extender Mode? | Answer | NETGEAR Support
