DLLM
May 19, 2019Guide
Orbi Voice isn't quite working
Just setup my RBK50V yesterday, with firmware 2.3.0.12, able to login with my Amazon account, I can see the Orbi Voice on my Alexa device list from the app too. However, if I talk to Orbi Voice "Ale...
- May 28, 2019I managed to get it working at last, by logging into the router through a browser (not the app), clicked a few OK button since it was my 1st time login via browser and all in sudden it works.
My finding is that the iPhone app cannot make the Orbi router/voice to 100% functional without a web base visit.
Anyway, I am all good now.
michaelkenward
May 20, 2019Guru - Experienced User
DLLM wrote:
I went to the app and can see the Orbi Voice on the network as Orbi Satellite-1" .
What is this network? What Orbi router are you using?
- DLLMMay 20, 2019Guide
The RBK50V set, and both my Echo, Echo spot are connected to the RBK50V, which are working fine.
- michaelkenwardMay 20, 2019Guru - Experienced User
That's the RBR50 router plus the RBS40V satellite.
I assume that the RBR50 is behaving as expected.
- DLLMMay 22, 2019Guide
Yes, the RBR50 works well, and the Orbi Voice also connected to it, but just it does not work when I talk to it "Alexa...". Tried a different Amazon account, same result.
