DLLM
May 19, 2019Guide
Orbi Voice isn't quite working
Just setup my RBK50V yesterday, with firmware 2.3.0.12, able to login with my Amazon account, I can see the Orbi Voice on my Alexa device list from the app too. However, if I talk to Orbi Voice "Ale...
- May 28, 2019I managed to get it working at last, by logging into the router through a browser (not the app), clicked a few OK button since it was my 1st time login via browser and all in sudden it works.
My finding is that the iPhone app cannot make the Orbi router/voice to 100% functional without a web base visit.
Anyway, I am all good now.
michaelkenward
May 20, 2019Guru - Experienced User
DLLM wrote:
I went to the app and can see the Orbi Voice on the network as Orbi Satellite-1" .
What is this network? What Orbi router are you using?
DLLM
May 20, 2019Guide
The RBK50V set, and both my Echo, Echo spot are connected to the RBK50V, which are working fine.
- michaelkenwardMay 20, 2019Guru - Experienced User
That's the RBR50 router plus the RBS40V satellite.
I assume that the RBR50 is behaving as expected.
- DLLMMay 22, 2019Guide
Yes, the RBR50 works well, and the Orbi Voice also connected to it, but just it does not work when I talk to it "Alexa...". Tried a different Amazon account, same result.
