JBW1
Apr 22, 2020Aspirant
Orbi Voice model RBS40V, Alexa not responding to voice command or playing through the speaker
My Orbi Voice shows connected to my Alexa device (Echo Dot), but will not respond to voice commands. It worked initially but once I unplugged my router to relocate it, the issue started. It will rece...
JBW1
Jul 21, 2020Aspirant
Nah, I have reset and even updated the firmware, and a piece of junk still doesn’t work. I’ve given up, and clearly no one from Netgear knows what’s going on with it because no one has bothered to even reply or try to fix it for me.
BrollAmerican
Jul 31, 2020Guide
I just got mine and finished setting up and I'm finding the same thing. The blue light is on indicating that Alexa is listening, but she won't do anything.
I got it to play music... not through Apple Music mind you. The fact that it doesn't work with Apple Music is a HUGE problem now. But since Alexa doesn't seem to hear anything it now won't shut off. I had to pull the power to get it to shut up.
I also noticed the red X next to the microphone randomly turned itself on.
Within 10 minutes I'm learning that this thing is a disappointing piece of junk. Netgear, what say you?
- JBW1Jul 31, 2020AspirantYeah, it’s very disappointing, but sadly not too surprising. Netgear customer service is a joke.
- MstrbigAug 12, 2020Master
When you factory reset the RBS40V, did you change the mode back to Orbi? When I got mine last week I had to change it to Orbi, then set it up.
- BrollAmericanAug 19, 2020Guide
Mstrbig wrote:When you factory reset the RBS40V, did you change the mode back to Orbi? When I got mine last week I had to change it to Orbi, then set it up.
Changing to Orbi mode apparently only works if connecting to an Orbi router, which I am not. I only found this out after going through the tedious process of resetting the Orbi Voice. Now it is even more useless than before. I have to reset the whole thing again and try to reconnect it in the way it was only working half-way well to begin with. This advice was terrible. Thanks for nothing.
