Pgharris
May 04, 2020Follower
Orbi voice not connecting to Alexa
Connected my rbs40v to the router and network as a second satellite and can’t get it to connect to amazon or Alexa to work
SFNESQ
May 07, 2020Aspirant
Same issue- Amazon keeps timing out when attempting to link the accounts.
- m9faridJul 03, 2020Aspirant
I have got the same issue. RBS40V working fine as the satellite but the Alexa is not working. When I called it, it says "not registered to ORBI" and asked to open ORBI app where no solution is provided there.
- Blanca_OJul 08, 2020NETGEAR Employee Retired
Hi m9farid
Kindly launch the Orbi App > tap Voice Controls > Details > Amazon Account. Please check if you are still logged into your Amazon Account.
Does restarting the Orbi Voice Satellite fix the issue?
What is the model number of the Orbi Router and firmware version?
Blanca
Community Team
