Nagamisan
May 31, 2020Initiate
Orbi Voice Power Adapter
I just bought from Amazon US and realised that the power adapter is not suitable to use in Singapore. (240V) I am thinking of getting a replacement set and netgear Singapore does not sell it. Any al...
- May 31, 2020
Look at the output voltage, polarity, and amperage.
You can use a 3rd party adapter as long as it has the same voltage and polarity. Amperage just needs to be at least the same. It can be more but if you go less, you can have instability.
May 31, 2020Guru - Experienced User
