Nagamisan
May 31, 2020Initiate
Orbi Voice Power Adapter
I just bought from Amazon US and realised that the power adapter is not suitable to use in Singapore. (240V) I am thinking of getting a replacement set and netgear Singapore does not sell it. Any al...
- May 31, 2020
Look at the output voltage, polarity, and amperage.
You can use a 3rd party adapter as long as it has the same voltage and polarity. Amperage just needs to be at least the same. It can be more but if you go less, you can have instability.
Nagamisan
Jun 04, 2020Initiate
I managed to get hold of a power adapter and it is working fine. The original netgear power plug has gotten too hot after initially using it for 20-30 mins and actually the plastic has melted slightly. Lesson learned, always checked the power voltage.
michaelkenward
Jun 04, 2020Guru - Experienced User
Very hot, Singapore.
Probably down to the strain on the transformer. At least it didn't go bang.
