Pean12
Jun 24, 2020Aspirant
Orbi Voice RBR50 Can't get Alexa Unable to apply settings
Was given a used Orbi RBR50 + Orbi Voice satellite. When I go to add Alexa to the Orbi Voice and login to Amazon, it goes to Amazon web page and ask me to "allow to sign in to Netgear Orbi Voice"...
Pean12
Jun 29, 2020Aspirant
Here what I get when I try and add Alexa controls. Any help pls?
TKF
Aug 07, 2020Aspirant
I have the same issue. Did you find a resolution?
- MstrbigAug 12, 2020Master
At this point if it were me, I would factory reset the RBS40v and try again. When I installed mine, I factory reset and configured it for Orbi, as it was in extender mode out of the box.
I routinely factory reset Orbi products just to be sure the default setting have not been tampered with.
