Route66Scott
May 07, 2020Tutor
Orbi Voice RBS40V Firmware V2.5.1.2 has typo in "Public_UPNP_gatedesc.xml" file... Help!
After setting up my Orbi system I discovered that the RBS40V satellite is causing my computers and media server to throw up constant errors. My Plex server has been repeating this set of errors e...
cgullett
May 23, 2020Aspirant
I don’t have your model, but I do have a RBW30 with exactly the same problem involving Plex. On the RBW30, RBS50 and RBR50 you change the page on your URL to /debug.htm and there is a checkbox To enable telnet. On the RBW30 the setting is persistent, on my 50s it does not survive a reboot.
- Route66ScottMay 23, 2020Tutor
The RBS40V does have a debug.htm page, but it has different settings and switches than the routers. It doesn't have a checkbox to enable telnet.
I've spent far too much time researching this with no luck. It's disappointing that this is all because of a single character typo.- Blanca_OJun 01, 2020NETGEAR Employee Retired
Hi Route66Scott
Let me check on this. I will get back to you for any updates.
Blanca
Community Team- Route66ScottJun 01, 2020TutorThank you, Blanca.
- leoaraucostaJul 29, 2020Aspirant
Hi,
Any news about enable telnet? I have Orbi Voice RBS40V Firmware V2.5.1.2 and doesn't have a checkbox to enable telnet.
Thanks!!
- MstrbigAug 12, 2020Master
My RBS40V has an Alexa MRM Debug Mode checkbox at the bottom.
