Route66Scott
May 07, 2020Tutor
Orbi Voice RBS40V Firmware V2.5.1.2 has typo in "Public_UPNP_gatedesc.xml" file... Help!
After setting up my Orbi system I discovered that the RBS40V satellite is causing my computers and media server to throw up constant errors. My Plex server has been repeating this set of errors e...
Route66Scott
May 23, 2020Tutor
The RBS40V does have a debug.htm page, but it has different settings and switches than the routers. It doesn't have a checkbox to enable telnet.
I've spent far too much time researching this with no luck. It's disappointing that this is all because of a single character typo.
Blanca_O
Jun 01, 2020NETGEAR Employee Retired
Hi Route66Scott
Let me check on this. I will get back to you for any updates.
Blanca
Community Team
- Route66ScottJun 01, 2020TutorThank you, Blanca.
- Blanca_OJun 07, 2020NETGEAR Employee Retired
Hi Route66Scott
This has been forwarded already to engineers. They requested to capture logs. Please check you inbox for additional information.
Blanca
Community Team
