Route66Scott
May 07, 2020Tutor
Orbi Voice RBS40V Firmware V2.5.1.2 has typo in "Public_UPNP_gatedesc.xml" file... Help!
After setting up my Orbi system I discovered that the RBS40V satellite is causing my computers and media server to throw up constant errors. My Plex server has been repeating this set of errors e...
Route66Scott
May 23, 2020Tutor
The RBS40V does have a debug.htm page, but it has different settings and switches than the routers. It doesn't have a checkbox to enable telnet.
I've spent far too much time researching this with no luck. It's disappointing that this is all because of a single character typo.
leoaraucosta
Jul 29, 2020Aspirant
Hi,
Any news about enable telnet? I have Orbi Voice RBS40V Firmware V2.5.1.2 and doesn't have a checkbox to enable telnet.
Thanks!!
- MstrbigAug 12, 2020Master
My RBS40V has an Alexa MRM Debug Mode checkbox at the bottom.
- CrimpOnNov 27, 2020Guru - Experienced User
Mstrbig wrote:My RBS40V has an Alexa MRM Debug Mode checkbox at the bottom.
Was that in regard to telnet? I checked the Alexa MRM Debug, but that does not enable telnet.
Wondering if one of the hacks that enabled telnet on the Nighthawk products would work on the RBS40V
- Route66ScottNov 27, 2020Tutor
I would be able to fix this issue if there was telnet access. But that doesn't fix a bug that affects every one of these devices.
I was contacted directly about this issue, and asked for logs. But after downloading the logs from both of my RBS40V units I was never given the info on where to send those logs.
I assume that Netgear outsources their coding, as there's no reason for this to still be an issue through multiple firmware revisions, when it's been pointed out as an issue.
