jescott3
Oct 13, 2020Guide
Orbi Voice RBS40V Region Set for Australia, I'm in US
I bought an Orbi Voice this week from the Netgear Store on Amazon. It was easy to set it up to work with my RBR50 and two RBS50 satellites. I purchased it to provide a LAN connection via ethernet for...
- Oct 14, 2020
I would first factory reset the Orbi Voice. Then re-install it. After you reinstall it, go to Orbilogin.com > Advanced > Administration > Firmware Update > Manual update and manually update the RBS40V, using the latest firmware you find here:
https://www.downloads.netgear.com/files/GDC/RBS40V/RBS40V-V2.6.1.4_1.0.1.zip
Mstrbig
Oct 14, 2020Master
jescott3
Oct 21, 2020Guide
Thanks, your suggestion worked. I already had managed to get the latest firmware update installed on the Orbi Voice, but it was still showing as the Australian version. Your suggestion worked because even though it reinstalled the firmware update, it quietly removed the Australian reference which meant my Orbi Voice is now seen as the U.S. version. Netgear's firmware moves in spooky and mysterious ways.
- FURRYe38Oct 21, 2020Guru - Experienced User
Be sure to check out the Orbi with Voice forum:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Enjoy.
