Kagancpa's avatar
Kagancpa
Follower
Aug 29, 2021
Orbi Voice RBS40V Smart Speaker Only
I have the Orbi Voice extender that never worked properly despite numerous attempts to fix with customer service.
Out of frustration, I decided to purchase the Nighthawk MK63 AX1800 and set a wifi 6 mesh system, which seems to initially work. I would like to use the Orbi voice as a smart speaker, so it is not a total loss. I reset to factory settings, as I could not get it to work as a smart speaker. I connected it via Ethernet to one of my Nighthawk satellites. It works, but it is not recognized by Orbi app.
Is there a better way to set it up so it is a wireless smart speaker and not the WiFi extender that never work properly?  The smart speaker was fine, despite its limitations.
1 Reply
